13 years agoQsys-script FAILED
Hi all, Finally moved to sdk ver 13 but bumped into another issue. aoc fails with the following message: ... Error: Qsys-script FAILED See all.log for details. all.log shows the follo...
13 years agoSounds like integrating the kernel hardware into the rest of the system is failing. Is your compilation machine set to the Turkish language? It could be a localization problem.
If you are compiling for the Nallatech A7 board try running "aocl install". Also when you run into that error try opening system.qsys, that file should be located in the directory named after your kernel. Assuming Qsys isn't in your path you should be able to open the system like this: <path of your Quartus installation>\sopc_builder\bin\qsys-edit system.qsys If you take a screen shot of that system and attach it here then I can take a look to see if I spot anything out of the ordinary. It should be comprised of three cores, a little clock/reset block, the kernel block, and a big blob of logic that represents the PCIe, SDRAMs, etc...
