13 years agoQsys-script FAILED
Hi all, Finally moved to sdk ver 13 but bumped into another issue. aoc fails with the following message: ... Error: Qsys-script FAILED See all.log for details. all.log shows the follo...
13 years agoAt 13.0 the tools changed quite a bit so I recommend going through the getting started guide again. The first thing to check is that the environment variables point at the 13.0 tools and that you have Stratix V device support installed.
Also in 13.0 you use 'aoc.exe' to compile the kernels now, acl is depricated.
