MTw
6 years agoQsys (Platform Designer) seq: add_fileset_file: No such file .. hps_AC_ROM.hex
I'm regenerating a hps system with the Platform Designer and receive a couple of errors during execution of script generate_hps_sdram.tcl Error: border: Error during execution of script generate_hp...
KennyT_altera
6 years agoFurther investigation, if the patch above does not work. You may use the workaround mention below:
- uninstalled Ubuntu 18.04 (If you have)
- uninstalled wsl
- re-installed wsl
- downloaded latest Ubuntu 18.04 from Microsoft Shop & installed it
- executed following on Ubuntu shell :
sudo apt-get update
sudo apt install wsl
sudo apt install dos2unix
sudo apt install make
sudo apt-get upgrade
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/tools/2019/wslpath---nios--ii-eds-installation-directory-or-nios-ii-project.html
