MTw
6 years agoQsys (Platform Designer) seq: add_fileset_file: No such file .. hps_AC_ROM.hex
I'm regenerating a hps system with the Platform Designer and receive a couple of errors during execution of script generate_hps_sdram.tcl Error: border: Error during execution of script generate_hp...
MTw
6 years agoHello Kenny T.
Can we have any update from you? When will we be able to generate a HPS using SDRAM with an Quartus Version greater than 18.1.1 Build 646 04/11/2019 SJ Standard Edition? Till this Version a HPS compilation was working, even running this great Windows 10 (Version 10.0.18363.720).
The jtagserver does not matter because it is the same on both versions installed parallel on this system. And the Windows Subsystem for Linux is deactivated. So please get us a solution!
