MTw
6 years agoQsys (Platform Designer) seq: add_fileset_file: No such file .. hps_AC_ROM.hex
I'm regenerating a hps system with the Platform Designer and receive a couple of errors during execution of script generate_hps_sdram.tcl Error: border: Error during execution of script generate_hp...
KennyT_altera
6 years agoCan you try out this solution?
Or
2)
Go to check the jtagserver.exe (same path as in the generate log) whether it is enabled in the firewall for all network types, see below:
jtagserver firewall
You may have to click on the 'Change settings' button with a shield icon on it before the firewall rules are editable - they are locked against being changed by software.
You might need to have the admin to do this.
