MTw
6 years agoQsys (Platform Designer) seq: add_fileset_file: No such file .. hps_AC_ROM.hex
I'm regenerating a hps system with the Platform Designer and receive a couple of errors during execution of script generate_hps_sdram.tcl Error: border: Error during execution of script generate_hp...
MTw
6 years agoHi,
I have checked the 3 solutions.
Solution 1 and 3 are literally the same. The linux subsystem wasn't activated. A reboot after closing the dialog brought no change in the behaviour of the Platform Designer...
Solution 2 has been negative, too. Every system variable pointed to the local drive C: The Variable HOMEDRIVE wa snot present, I created it pointing to a local folder on my C: drive.
The error is the same till now.
Sincerely yours,
Mirco
