12 years ago --- Quote Start --- Okay, I figured this one out. I installed Quartus on this machine to the /opt directory using sudo. It created a .altera.quartus file at my user root directory but it was owned by root and part of the root group, thus I didn't have permissions to write to the files in that directory. Quartus must use the quartus2.ini and quartus2.qreg files in that directory to store state information. I chown'd the folder and files and the problem is solved. --- Quote End --- I can't understand your way to fix this Problem. Can you, or anybody else, explain what I musst change on my System to solve this Problem. Actually I start Quartus as Admin an I can Change the " IP search path".
