Altera_ForumHonored Contributor12 years agoQsys instance parameters in generated verilog I have a Qsys project, where I have added a couple parameters in the "Instance Parameters" tab. Using the 'instance script', I can ensure that these parameters are propagated to my instances. Howev...Show More
Altera_ForumHonored Contributor12 years agoI haven't figured this out yet, but an answer would be greatly appreciated!
Recent DiscussionsMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verification
