9 years agoQsys HPS(Hard Processor Ssystem) Errors
I'm trying to generate a system including HPS(Hard Processor System) of the Cyclone V SoC in Quartus Prime Qsys. At the "Generate HDL" stage I got the following errors. I'm not expecting all the erro...
9 years agoThe "memory" and "hps_io" conduits, as mentioned in the warnings, must be exported so they can be connected to the dedicated HPS pins. You also have to run a script, generated by Qsys, that sets up the memory I/O pins (the name of the script escapes me right now). I'm not sure if this is the cause of your issues, but it can't hurt to try it.
Qsys relies on Java, so also make sure you've got Java up to date.
