9 years agoQsys HPS(Hard Processor Ssystem) Errors
I'm trying to generate a system including HPS(Hard Processor System) of the Cyclone V SoC in Quartus Prime Qsys. At the "Generate HDL" stage I got the following errors. I'm not expecting all the erro...
9 years agoHere are the warnings that I got before generating hdl. I also attached my Qysys configuration. But as I said, it isn't related to the configuration or presets of the HPS. I tried different variations already.
One more update: A friend also tried this and got exactly the same errors. We both use Windows 10. But when I tried it in a different computer with windows 8 generations is completed without errors. I suspect the last update of Windows 10 has messed up something within Qsys. Warning: test.hps_0: "Configuration/HPS-to-FPGA user 0 clock frequency" (desired_cfg_clk_mhz) requested 100.0 MHz, but only achieved 97.368421 MHz Warning: test.hps_0: "QSPI clock frequency" (desired_qspi_clk_mhz) requested 400.0 MHz, but only achieved 370.0 MHz Warning: test.hps_0: 1 or more output clock frequencies cannot be achieved precisely, consider revising desired output clock frequencies. Warning: test.hps_0: hps_0.memory must be exported, or connected to a matching conduit. Warning: test.hps_0: hps_0.hps_io must be exported, or connected to a matching conduit.
