10 years agoQsys, How do you determine the Address for an Avalon-MM Block?
Ok, so I've managed to compile my SoC block with Qsys, I had some prior error but it was due to not setting the TOP module correctly. Now it's compiled and I even managed to add some LEDs sign...
10 years agoThis is what I got:
altera_hps2fpga_bridge fpgabridge.2: fpga bridge registered as device hps2fpga
altera_hps2fpga_bridge fpgabridge.2: init-val not specified
altera_hps2fpga_bridge fpgabridge.3: fpga bridge registered as device lwhps2fpga
altera_hps2fpga_bridge fpgabridge.3: init-val not specified
altera_hps2fpga_bridge fpgabridge.4: fpga bridge registered as device fpga2hps
altera_hps2fpga_bridge fpgabridge.4: init-val not specified Also, while looking at /sys/class/fpga-bridge/ I found the 3 bridges enabled:
root@socfpga:/sys/class/fpga-bridge# ls
fpga2hps hps2fpga lwhps2fpga
root@socfpga:/sys/class/fpga-bridge# cat */enable
1
1
1
