10 years agoQsys, How do you determine the Address for an Avalon-MM Block?
Ok, so I've managed to compile my SoC block with Qsys, I had some prior error but it was due to not setting the TOP module correctly. Now it's compiled and I even managed to add some LEDs sign...
10 years ago --- Quote Start --- Look at the registers in HPS for the interface to fpga fabric you are using. The interface should be initialized when Linux boots, but there is a lot that can go wrong and cause the bridge to not be initialized. --- Quote End --- Where should I look for that?
