10 years agoQsys, How do you determine the Address for an Avalon-MM Block?
Ok, so I've managed to compile my SoC block with Qsys, I had some prior error but it was due to not setting the TOP module correctly. Now it's compiled and I even managed to add some LEDs sign...
10 years agoLook at the registers in HPS for the interface to fpga fabric you are using. The interface should be initialized when Linux boots, but there is a lot that can go wrong and cause the bridge to not be initialized.
