11 years agoQsys HAL error on Quartus II 15.0/Ubuntu
I'm trying to rebuild my Qsys design on Quartus II 15.0, running on Ubuntu 14.04.2 64-bit. It's an Arria II GX design, and when I try to build the PCIe core I get the message:
2015.07.13.18:44:01 Info: altgx_internal: qmegawiz -silent module=alt4gxb LOCKDOWN_EXCL=PCIE IP_MODE=PCIE_HIP_8 gxb_analog_power=AUTO tx_analog_power=AUTO elec_idle_infer_enable=false tx_allow_polarity_inversion=false rx_cdrctrl_enable=true reconfig_togxb_port_width=4 reconfig_fromgxb_port_width=17 hip_tx_clkout rx_elecidleinfersel fixedclk rx_signaldetect rateswitchbaseclock tx_pipemargin tx_pipedeemph rateswitch reconfig_dprio_mode=1 reconfig_clk reconfig_fromgxb reconfig_togxb enable_0ppm=false pll_powerdown intended_device_family=arriaii starting_channel_number=0 deviceFamily="Arria II GX" wiz_subprotocol="Gen 1-x4" OPTIONAL_FILES=NONE sopc_pcie_hip_altgx_internal.v2015.07.13.18:44:08 Error: process 8615: arguments to dbus_move_error() were incorrect, assertion "(dest) == NULL || !dbus_error_is_set ((dest))" failed in file ../../dbus/dbus-errors.c line 282.
2015.07.13.18:44:08 Error: libhal.c 3483 : Error unsubscribing to signals, error=The name org.freedesktop.Hal was not provided by any .service files
2015.07.13.18:44:08 Info: altgx_internal: "pcie_hip" instantiated altera_pcie_internal_altgx "altgx_internal"
2015.07.13.18:44:08 Error: Generation stopped, 76 or more modules remaining
That error comes up whether I'm running Qsys from the GUI or just ip-generate from the command line. I can't think of why Qsys would need DBus for anything, but there you go. Anyone have any ideas? Putting in an SR will just get me told that Ubuntu isn't supported.No RepliesBe the first to reply
