KC1
5 years agoQsys generated msim_setup.tcl missing some files
Hello, I am trying to simulate a qsys component, so I generated simulation files from Qsys. I am trying to compile the generated msim_setup.tcl file, but I get errors for a few .v files:
"Instantia...
sstrell
5 years agoSanity check: so you're running this Tcl script in ModelSim, not Platform Designer, correct? The script is generated by Platform Designer (not called Qsys anymore) to be run in ModelSim to simulate test bench systems generated by Platform Designer.
If you're running it correctly, it doesn't make sense that the generated file would throw this type of error. Make sure in ModelSim that you've used the Change Directory option to point to the location of the msim_setup.tcl file.
