11 years agoQSYS flattens our design hierarchy
Hi all, We are migrating from Xilinx to Altera and so far everything is running ok. As an alternative to Xilinx IP-integrator, we've now moved to QSYS. Here we get problems. First issue: I...
11 years ago --- Quote Start --- Project management has accepted the hard paths in the qip-file for now, so we have something we can work with. --- Quote End --- Arguably they are not hard paths, since they are dynamically generated by the Tcl script :) --- Quote Start --- However, I do not consider this case closed until Altera Qsys allows library assignment per IP block. This is so weird to me. VHDL libraries have been defined in the IEEE 1076-1987 VHDL standard already (section 11.2). Why is Altera still supporting them so badly after 28(!!) years? --- Quote End --- I agree. Their VHDL support is terrible in multiple places, check out the comments at the end of the Avalon-MM BFM tutorial I wrote: https://www.ovro.caltech.edu/~dwh/correlator/cobra_docs.html https://www.ovro.caltech.edu/~dwh/correlator/pdf/altera_avalon_bfm_master.pdf https://www.ovro.caltech.edu/~dwh/correlator/pdf/altera_avalon_bfm_master.zip Cheers, Dave
