11 years agoQSYS flattens our design hierarchy
Hi all, We are migrating from Xilinx to Altera and so far everything is running ok. As an alternative to Xilinx IP-integrator, we've now moved to QSYS. Here we get problems. First issue: I...
11 years agoThank you Dave, I will try your suggestion.
Project management has accepted the hard paths in the qip-file for now, so we have something we can work with. However, I do not consider this case closed until Altera Qsys allows library assignment per IP block. This is so weird to me. VHDL libraries have been defined in the IEEE 1076-1987 VHDL standard already (section 11.2). Why is Altera still supporting them so badly after 28(!!) years?
