11 years agoQSYS flattens our design hierarchy
Hi all, We are migrating from Xilinx to Altera and so far everything is running ok. As an alternative to Xilinx IP-integrator, we've now moved to QSYS. Here we get problems. First issue: I...
11 years agowhy do my posts in this tread suddenly require moderator approval?
Is it when I use the word "Xilinx" in a post? <- no this works. Strange. What I tried to say: We are trying to migrate from Xilinx to Altera. Xilinx IP-integrator has no issues with libraries whatsoever. Seems logical, as libraries in VHDL have been there like forever. It is perfectly valid VHDL to use them. We build an extensive IP database on top of that. Changing filenames (and entity/package names) will be a lot of work. Furtermore, company policy would require us to re-verify, re-validate and re-test all the code and our devices if we change the sources. It is kind of hard for me to sell this to my superiors. When migrating from ISE to Quartus II I notices that Quartus II has settings to change and tweak Everything! So I don't understand why Qsys seems to be the opposite, offering little settings to change. *not even the VHDL library per block!* @Dave: I tried that, but I get the problem that only the .qip file is copied, and not the vhdl sources. As a result the qip file does not work, as it contains relative paths. Example:set_global_assignment -name VHDL_FILE -hdl_version VHDL_2008 -library UdpToFrame
