11 years agoQSYS flattens our design hierarchy
Hi all, We are migrating from Xilinx to Altera and so far everything is running ok. As an alternative to Xilinx IP-integrator, we've now moved to QSYS. Here we get problems. First issue: I...
11 years agoI'm not sure that is possible.....
Considering Common_pkg in TsToUdp is NOT the same as Common_pkg in UdpToFrame, it might be better just to give them different names. Did you try generating with the folder fix? Does this still cause overwrites? I'm thinking that maybe if these files are the same name but in separate folders, then you shouldn't have an issue even if they are referenced to the same "library".
