11 years agoQSYS flattens our design hierarchy
Hi all, We are migrating from Xilinx to Altera and so far everything is running ok. As an alternative to Xilinx IP-integrator, we've now moved to QSYS. Here we get problems. First issue: I...
11 years agoThanks!
So I managed to get the files in a seperate directory usingadd_fileset_file .//.vhd VHDL PATH /.vhd That solves issue# 1 Issue# 2 is still there: all files are compiled into one library. I have tried the following: - change the value
. Which is probably a stupid idea :oops:set %libraryName% "TstoUdp" - do a TCL replace action using "get_qip_strings" and "set_qip_strings". But is seems get_qip_strings does not work and that set_qip_strings can only be used to add extra strings, not to replace or change existing ones.
