14 years ago
Qsys doesn't program flash correctly
I am using the latest 11.1 sp2. I have a project that came from 10.1 with SOPC. It has been working in custom hardware for over 5 years. I compiled, debugged and programmed into the flash just fine using SOPC as the system generator using 11.1. It just works as it should.
When I converted the project to use Qsys, it will debug and run fine under the debugger, but I can't get it to run with the EPCS flash. It took about a week to get all the many conversion issues sorted out, but I am at a loss to find why it won't boot from flash. It looks like the SOF won't even boot when I use the flash programmer. If I program just the pof into the flash using the normal programmer, the hardware at least boots just fine.
What issue does QSYS make that won't let the flash programmer work?
    i had the same problem with you ,in sopc builder it works well,but convert to qsys,it not boot correctly
