gyuunyuu
Contributor
5 years agoQsys component generation on the fly
Is it possible to create Qsys component in such a way that its interfaces can be changed based on options selected in Qsys when we are about to add it? e.g we can select how many Avalon sink interfac...
SyafieqS
5 years agoHi Hassan,
You may need to refer to link below related to Control Interfaces Dynamically with an Elaboration Callback. You can allow user parameters to dynamically control your component's behavior with an elaboration callback procedure during the elaboration phase. Using an elaboration callback allows you to change interface properties, remove interfaces, or add new interfaces as a function of a parameter value.
