9 years agoQsys component editor: No modules found when analyzing null
Hello, I am facing a strange Qsys problem when trying to add new components. After I added the synthesis files, I click on "Analyze Synthesis Files" and the appearing dialog says me, that there are n...
8 years agoJust following on to this post. My initial command line command only provides a basic syntax check. To get a full aelaboration from the command line use the following:
quartus_map <project_name> --analysis_and_elaboration --source <filename and path>
