9 years agoQsys component editor: No modules found when analyzing null
Hello, I am facing a strange Qsys problem when trying to add new components. After I added the synthesis files, I click on "Analyze Synthesis Files" and the appearing dialog says me, that there are n...
9 years agoI have had the same problem in QSYS, it is very irritating. I have been working around it by doing the HDL analysis at the command line. This allows you to check a single file at a time but at least gives some decent output that helps find the syntax errors.
quartus_map <project_name> --analyze_file=<filename and path> This will find syntax errors. Note that you don't actually need an active project to run this command. You can just fill project name with any text, it just needs something, it will create a base project for you. Once you have a base project you can re-run the command without the --analyze_file hook to do basic synthesis analysis.
