mke
4 years agoQsys Avalon bus symbol width
I have a question regarding the Avalon bus symbol width.
First, I have a custom IP with Avalon bus data width 576 bits. And I connected Avalon BFM to it in order to simulate it and here is ...
mke
4 years agoAdditional:
I played a bit with the system with just two BFM-s connected together. If I use 8-bit symbol width, 64 symbols, 32-bit address, and addressing mode as "word" for both master and slave then everything is fine.
But if I change the symbol width to 9 (both master and slave) I have to use a 33-bit address for the master while the slave did not change, except the symbol width. Qsys complains about masters insufficient address range otherwise. Could you please explain to me what I am overlooking here?
BR, Madis
