9 years agoQSYS 17 .0 pro missing .sopcinfo
I have a qsys nios design that is working fine in Quartus 16.1 pro. Did an upgrade to Quartus 17.0 prime pro and after re-generating the qsys project, the <project>.sopcinfo file was removed and n...
9 years agoFound it.
The <project>.sopcinfo file used to be generated into the same path as the <project>.qsys file. Now it's placed in the generated <project> folder. Makes sense to have all generated files in the same place. Also all sub components (under the ip/ folder) gets their own .sopcinfo In eclipse Nios-SBT you can't edit the BSP to reference a new .sopcinfo so you have to manually edit the settings.bsp file to point to the new location. Or create a new BSP for the QSYS 17.0 project.
