9 years agoQSYS 17 .0 pro missing .sopcinfo
I have a qsys nios design that is working fine in Quartus 16.1 pro. Did an upgrade to Quartus 17.0 prime pro and after re-generating the qsys project, the <project>.sopcinfo file was removed and n...
9 years agoI'm presuming you are using an Arria 10 device. It should be there in the same directory as the .qsys file. I don't think the file locations were moved around between 16.1 and 17.0. Maybe try trashing the generated system's folder and regenerating.
