14 years agoqsys - Avalon MM master export
Hi, I was not able to find in a couple of searches an answer to my question, so here I start a new thread: I need to make Qsys export an Avalon-MM Master for configuring my hand-coded comp...
11 years ago --- Quote Start --- Why not just use a pipeline bridge and export the master interface for it? --- Quote End --- Hi, I have the same need. I simply exported the master interface, then got this error from eclipse while downloading the software: No Nios II target connection paths were located. Check connections and that a Nios II .sof is downloaded. Here is my thread: http://www.alteraforum.com/forum/showthread.php?t=48522 Could you please tell me the right way to export the master interface or the reason why I got the error?
