12 years agoqsf file
i generate the qsf file from c# to text file and then i load it to quartos 13.0. 1. i need to know if the location of the string commands must be at fixed places in the file or it could be any were in the file ? is there a legality at the location of those commands ? F.E : At file that i compiled i see at the qsf file first of all the "set_global_assignment" commands , then "set_location assingment" commands and then "set_instance_assignment" commands (File Attached at txt format) it should be at this order ? 2.Are there global commands or fixed strings at the qsf file that doesn't change no matter what the designer choose ? Thanks for help. :)
