8 years agoqsf file setting is not correct, how to get correct qsf file?
Dear all, When I compile OpenCL kernel to generate aocx file by using the command "aoc device/vector_add.cl -o bin/vector_add.aocx --board de5a_net_e1 --report", I met an error "The junction te...
8 years agoTerasic has two DE5a-Net boards. One uses an I2 device, the other an E1 device. They provide separate BSPs for these two boards. You seem to be using the wrong BSP.
