15 years ago
qmegawiz command line troubles
I'm trying to create an altsyncram with the following command:
qmegawiz -silent wizard="RAM: 1-PORT" WIDTH_A=8 WIDTHAD_A=8 myram.v
However, I get the error message:
Error: Incorrect or unknown megafunction RAM: 1-PORT
Error: Megafunction name not known or cannot be found
qmegawiz   <file_name>
   The last argument to qmegawiz should be the file name.
  options:
   -help or -h             Displays this help
   module=<mf_name>        Specifies the megafunction name to create
                           new wrappers from command line
                           Megafunction parameters and ports can
                           be specified in the command line
                           Megafunction name is optional when editing
                           existing wrappers
   entity=<mf_name>        same as module=<mf_name>
   megafunction=<mf_name>  same as module=<mf_name>
   wizard=<wizard_name>    Specifies the wizard name to create
                           Wizard name is optional when editing wrappers
   plugin=<wizard_name>    same as wizard=<wizard_name>
   -f:<param_file>         Gets parameter assignments and port selections
                           from the given file.
   -p:<working_dir>        Sets the default working directory
Megafunction parameters should be specified in the format <par_name>=<value>
Megafunction port usage can be set as <port>=used or <port>=unused
Optional output files generated by the megawizard can be selected/deselected
through the parameter OPTIONAL_FILES.
   INST                    controls the generation of <variation>_inst.v
   INC                     controls the generation of <variation>.inc
   CMP                     controls the generation of <variation>.cmp
   BSF                     controls the generation of <variation>.bsf
   BB                      controls the generation of <variation>_bb.v
   WAVE                    controls the generation of sample waveform file(s)
                           (wherever the wizard supports it)
   SIM_NETLIST             controls the generation of simulation netlist file
   SYNTH_NETLIST           controls the generation of synthesis netlist file
   ALL                     generates all the applicable optional files
   NONE                    disables the generation of all optional files
The above values when preceded by a '-' disable the generation of the file
Multiple files can be enabled or disabled as shown below
   OPTIONAL_FILES=NONE|INC|CMP enables include and component files only
   OPTIONAL_FILES=ALL|-INC enables all files except include file
List of megafunctions supported by the qmegawiz command line mode are
   altclkctrl
   altfp_sincos
   altfp_matrix_mult
   altfp_mult
   scfifo
   altiobuf_bidir
   altfp_abs
   alt4gxb
   altlvds_tx
   altfp_inv
   altecc_decoder
   altiobuf_in
   altfp_matrix_inv
   altmult_accum
   altlvds_rx
   altfp_add_sub
   altmult_complex
   altddio_bidir
   altddio_out
   altasmi_parallel
   altfp_log
   altotp
   alt_c3gxb
   altiobuf_out
   altfp_inv_sqrt
   altecc_encoder
   altfp_div
   altfp_compare
   altfp_exp
   altfp_sqrt
   altfp_convert
   alttemp_sense
   dcfifo
   altshift_taps
   altsyncram
   alt2gxb
   altddio_in
   altpll
   altremote_update
   altpll_reconfig
However when I try:
qmegawiz -silent wizard="RAM: 1-PORT" myram.v
It seems to create the ram with default values (ie it works). Does anyone know what my problem is?
Thank you,
Kevin
1 Reply
  • MTosc's avatar
    MTosc
    ​I have the exact same problem.
    Using the command:
    qmegawiz -silent wizard="RAM: 1-PORT" -f:myram_parameters.txt myram.vhd
    i am unable to create a custom single port RAM. Instead the same error as in the original question pops up.
    ADDRESS_ACLR_A=NONE
    INDATA_ACLR_A=NONE
    INTENDED_DEVICE_FAMILY=MAX10
    NUMWORDS_A=2048
    OPERATION_MODE=SINGLE_PORT
    OUTDATA_ACLR_A=NONE
    OUTDATA_REG_A=CLOCK0
    POWER_UP_UNINITIALIZED=FALSE
    WIDTHAD_A=11
    WIDTH_A=32
    WIDTH_BYTEENA_A=1
    WRCONTROL_ACLR_A=NONE
    DEVICE_FAMILY=MAX10
    CBX_AUTO_BLACKBOX=ALL
    address_a
    clock0
    q_a
    Also i noticed that the altsyncram module is not being listed as a supported megafunction anymore:
       alt2gxb
       alt4gxb
       altasmi_parallel
       altclkctrl
       altddio_bidir
       altddio_in
       altddio_out
       altecc_decoder
       altecc_encoder
       altfp_abs
       altfp_add_sub
       altfp_atan
       altfp_compare
       altfp_convert
       altfp_div
       altfp_exp
       altfp_inv_sqrt
       altfp_inv
       altfp_log
       altfp_matrix_inv
       altfp_matrix_mult
       altfp_mult
       altfp_sincos
       altfp_sqrt
       altiobuf_bidir
       altiobuf_in
       altiobuf_out
       altlvds_rx
       altlvds_tx
       altmult_accum
       altmult_complex
       altotp
       altparallel_flash_loader
       altpll_reconfig
       altpll
       altremote_update
       altserial_flash_loader
       altshift_taps
       alttemp_sense
       alt_c3gxb
       alt_fault_injection
       dcfifo
       scfifo
    PS: Using the qmegawiz GUI works flawlessly, why doesn't the command line tool??
