18 years agofrom Altera's tech support (reply to my service request):
--- Quote Start --- I have tested some projects in my computer in v7.2sp3. I don’t find such error. Could you please check if your project path contains any space, or your Quartus II and Nios II IDE installation directory contain space? --- Quote End --- And an update on my part-- I went back to an OLD archive from January and began copying portions of the .SOPC and .PTF files from the Jan version to the current version using a GUI-based diff tool (we use Beyond Compare).. After tons of changes I was sure things would just crash and burn, but I thought I'd try it anyway, and don't'cha'know, things started working. The 3rd PLL output that I wanted showed up (that's the stuff I was copying, because it USED to be enabled and I wanted to RE-enable it), AND I am now able to open the PLL megawizard... But I think something OUTSIDE the project has changed, too. Because now I can go back to the previously "non-working" copy of the project and it works fine now. (spooky music playing) I am wondering about path names, environment variables, and other non-project-specific settings at this point... The case is still open, but at least I can push forward with the design now ... Hopefully I can help narrow this down for Altera and you guys .. ..dane
