Q18.1 fails when NIOSf present (error 13223)
Thanks for your reply...
The error is still here when having smaller path length (directory: work/niosf).
The project is as simple as the implementation of one NIOS (with onchip memory).
I use Quartus 18.1.2 Build 277 Pro Edition but my maintenance license is expired for Quartus (not for NIOS IP). But as I target Cyclone 10 GX, I understood that license is not required. May it be the source of the problem?
Hi @Busy ,
- If Design works fine with Nios ii/e and only fails with Nios ii/f, It should be license issues.
Can you check and confirm?
For License Please refer to Intel® FPGA Licensing Support Center to get started, find information on license types, getting a license file,setting up a license file, and resolving license-related issues.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/support-centers/licensing.html
Otherwise for license file request and activation, log in your “My Intel” account to find Intel FPGA Self Service License Center.
Anand
