11 years agoQ14.1 TimeQuest Timing Closure Recommendations crash
When I click "Run Report Timing Closure Recommendations" TimeQuest crash, there are patch?
problem details Error: *** Fatal Error: Access Violation at 0X00007FFF1C987284 Module: quartus_sta.exe Stack Trace: 0x47283: HDB_ENUM_OPTION::get_value + 0x3 (DB_HDB) 0x2c5d9a: sta_rebuild_and_preprocess_tdb + 0x8972 (TSM_STA) 0x2c4c69: sta_rebuild_and_preprocess_tdb + 0x7841 (TSM_STA) 0x243e18: STA_NET_DELAY_MGR::operator= + 0x21f8 (TSM_STA) 0x2c6437: sta_rebuild_and_preprocess_tdb + 0x900f (TSM_STA) 0x161e2: TclNRRunCallbacks + 0x62 (tcl86) 0x17a65: TclEvalEx + 0xa65 (tcl86) 0x18257: Tcl_Eval + 0x37 (tcl86) 0x214cf: ATCL_OBJ::type + 0x3cf (ccl_atcl) 0x161e2: TclNRRunCallbacks + 0x62 (tcl86) 0x17a65: TclEvalEx + 0xa65 (tcl86) 0xa6f8b: Tcl_FSEvalFileEx + 0x22b (tcl86) 0xa5646: Tcl_EvalFile + 0x36 (tcl86) 0x13962: qexe_evaluate_tcl_command + 0x582 (comp_qexe) 0x12adc: qexe_apply_ini_vars + 0x29ec (comp_qexe) 0x17496: qexe_process_cmdline_arguments + 0x23a6 (comp_qexe) 0x18381: qexe_standard_main + 0xc1 (comp_qexe) 0xcad8: msg_initialize_out_of_memory_handler + 0x378 (CCL_MSG) 0xe20c: msg_set_stack_size + 0x7c (CCL_MSG) 0x5990: mem_gen_get_project_output_directory + 0x64 (ccl_mem) 0xc721: msg_exe_main + 0xa1 (CCL_MSG) 0x13d1: BaseThreadInitThunk + 0x21 (KERNEL32) 0x6e953: RtlUserThreadStart + 0x33 (ntdll) End-trace Executable: quartus_sta Comment: None system information Platform: windows64 OS name: Windows 7 OS version: 6.2 quartus ii information Address bits: 64 Version: 14.1.1 Build: 190 Edition: Web Edition6 Replies
Service Request# 11135344
From Support: This had been fixed in Q15.0
--- Quote Start --- From Support: This had been fixed in Q15.0 --- Quote End --- Do you know when Q15.0 will be released? - Altera_Forum
Quartus II 15.0 was released on early of May2015.
--- Quote Start --- From Support: This had been fixed in Q15.0 --- Quote End --- Thanks for sharing that this had been fixed in QII 15.0. - Altera_Forum
Hi joe306,
You can download the latest Quartus II 15.0 update 1 from the following link: http://dl.altera.com/15.0/?edition=subscription
