11 years agoI'mm not using this constellation (I've implemented the active serial programming option to access the config EEPROM),but I think the problem is more the JTAG I/F rather anything "beyond" (SFL,...). Have you tried to connect the USB-Blaster to your Hardware and run an "Auto-Detect" to validate this interface is ok? While I'm not sure this is relevant for all Cyclone IV, my board uses a EP4CE15 whose JTAG "ID" is identical to a Cyclone III Device, thus with "Auto Detect" I have to choose the Cyclone IV first... Maybe your QII 13.1 issue is, that the Cyclone IV is identified as a Cyclone III...
If the JTAG Connection is ok, I'd try to configure the FPGA via JTAG with your's programming file .sof directly to check step by step... Finally - if the *.JIC file was generated by QII 11.1 it might be worth to generate this by QII 13.1, maybe this is a Version incompatibility issue...
