Proper way of connecting EPCQ configuration to Nios II-based system
Can you try to program example given in the link also follow the steps from AN736
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an736.pdf
Let me know if your are able to program it or if you need any further assistance.
Anand
Hi, Anand
We have solved all problems with hardware right now (please read log in my second message). The only problem
is that quartus_pgm --nios2 crashes with access violation after successful programming. This problem is also
present in Quartus 17.1 with the same trace message.
As a solution, I've moved from using quartus_pgm with --nios2 flag to JIC-file based programming flow.
I've composed JIC-file with SOF data, Nios II program, DSP program and custom settings.
And it works perfectly (erasing only modified regions) and programming succeeds every time.
Yurii
