Proper way of connecting EPCQ configuration to Nios II-based system
Can you try to program example given in the link also follow the steps from AN736
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an736.pdf
Let me know if your are able to program it or if you need any further assistance.
Anand
- YMona7 years ago
Hi, Anand
We have solved all problems with hardware right now (please read log in my second message). The only problem
is that quartus_pgm --nios2 crashes with access violation after successful programming. This problem is also
present in Quartus 17.1 with the same trace message.
As a solution, I've moved from using quartus_pgm with --nios2 flag to JIC-file based programming flow.
I've composed JIC-file with SOF data, Nios II program, DSP program and custom settings.
And it works perfectly (erasing only modified regions) and programming succeeds every time.
Yurii
