Proper way of connecting EPCQ configuration to Nios II-based system
I think I've figured out the root cause of all problems. EPCQ reset was not connected to Nios II debug_reset_request signal.
But the problem with access violation persists. Every time quartus_pgm finishes programming of EPCQ flash (with --nios2 option)
it returns code 0x0 and programs everything correctly, but displays an access violation message.
Below is the full log of quartus_pgm utility. First it programs *.sof file, then programs *.flash files.
Info: *******************************************************************
Info: Running Quartus Prime Programmer
Info: Version 18.1.0 Build 625 09/12/2018 SJ Lite Edition
Info: Copyright (C) 2018 Intel Corporation. All rights reserved.
Info: Your use of Intel Corporation's design tools, logic functions
Info: and other software and tools, and its AMPP partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Intel Program License
Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
Info: the Intel FPGA IP License Agreement, or other applicable license
Info: agreement, including, without limitation, that your use is for
Info: the sole purpose of programming logic devices manufactured by
Info: Intel and sold by Intel or its authorized distributors. Please
Info: refer to the applicable agreement for further details.
Info: Processing started: Wed Feb 06 12:37:53 2019
Info: Command: quartus_pgm -c "USB-Blaster [USB-0]" -m jtag -o p;mk.sof
Info (213045): Using programming cable "USB-Blaster [USB-0]"
Info (213011): Using programming file mk.sof with checksum 0x00BECB69 for device
EP4CE40F23@1
Info (209060): Started Programmer operation at Wed Feb 06 12:37:54 2019
Info (209016): Configuring device index 1
Info (209017): Device 1 contains JTAG ID code 0x020F40DD
Info (209007): Configuration succeeded -- 1 device(s) configured
Info (209011): Successfully performed operation(s)
Info (209061): Ended Programmer operation at Wed Feb 06 12:37:57 2019
Info: Quartus Prime Programmer was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 298 megabytes
Info: Processing ended: Wed Feb 06 12:37:57 2019
Info: Elapsed time: 00:00:04
Info: Total CPU time (on all processors): 00:00:01
Info: Processing started: Wed Feb 06 12:37:57 2019
Info: Command: quartus_pgm --nios2 -c "USB-Blaster [USB-0]" --base=0x800000 --de
vice=1 --epcq --csr=0xc00000 --program mk.flash
Info (18932): Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Info (18932): Resetting and pausing target processor:
Info (18932): OK
Info (18932): : Checksumming existing contents
Info (18932): 00000000 : Verifying existing contents
Info (18932): 00010000 : Verifying existing contents
Info (18932): 00020000 : Verifying existing contents
Info (18932): 00030000 : Verifying existing contents
Info (18932): 00040000 : Verifying existing contents
Info (18932): 00050000 : Verifying existing contents
Info (18932): 00060000 : Verifying existing contents
Info (18932): 00070000 : Verifying existing contents
Info (18932): 00200000 : Verifying existing contents
Info (18932): 00210000 : Verifying existing contents
Info (18932): 00220000 : Verifying existing contents
Info (18932): 00230000 : Verifying existing contents
Info (18932): 00300000 : Verifying existing contents
Info (18932): 003C0000 : Verifying existing contents
Info (18932): 00200000 : Reading existing contents
Info (18932): 00210000 : Reading existing contents
Info (18932): 00220000 : Reading existing contents
Info (18932): 00230000 : Reading existing contents
Info (18932): 00300000 : Reading existing contents
Info (18932): 003C0000 : Reading existing contents
Info (18932): Checksummed/read 850kB in 0.0s
Info (18932): 00200000 ( 0%): Erasing
Info (18932): 00210000 (16%): Erasing
Info (18932): 00220000 (33%): Erasing
Info (18932): 00230000 (50%): Erasing
Info (18932): 00300000 (66%): Erasing
Info (18932): 003C0000 (83%): Erasing
Info (18932): Erased 384kB in 0.0s
Info (18932): 00000000 ( 0%): Programming
Info (18932): 00010000 ( 0%): Programming
Info (18932): 00020000 ( 0%): Programming
Info (18932): 00030000 ( 0%): Programming
Info (18932): 00040000 ( 0%): Programming
Info (18932): 00050000 ( 0%): Programming
Info (18932): 00060000 ( 0%): Programming
Info (18932): 00070000 ( 0%): Programming
Info (18932): 00200000 ( 0%): Programming
Info (18932): 00210000 ( 7%): Programming
Info (18932): 00220000 (15%): Programming
Info (18932): 00230000 (22%): Programming
Info (18932): 00300000 (30%): Programming
Info (18932): 003C0000 (37%): Programming
Info (18932): Programmed 719KB +131KB in 0.0s
Info (18932): Did not attempt to verify device contents
Info (18932): Leaving target processor paused
Info: Peak virtual memory: 268 megabytes
Info: Processing ended: Wed Feb 06 12:38:24 2019
Info: Elapsed time: 00:00:27
Info: Total CPU time (on all processors): 00:00:00
*** Fatal Error: Access Violation at 0X000007FEF32E15C3
Module: quartus_pgm.exe
Stack Trace:
0x115c2: AJI_CLIENT::disconnect_all + 0xc2 (jtag_client)
0x21c37: DllMain + 0x27 (jtag_client)
0x22420: __DllMainCRTStartup + 0x8c (jtag_client)
0x3778a: LdrShutdownProcess + 0x1da (ntdll)
0x3c1df: RtlExitUserProcess + 0x8f (ntdll)
0x229a6: _initterm_e + 0x21a (MSVCR120)
0x22cf1: __tmainCRTStartup + 0x125 (quartus_pgm)
0x159cc: BaseThreadInitThunk + 0xc (kernel32)
0x5385c: RtlUserThreadStart + 0x1c (ntdll)
End-trace
Quartus version is 18.1, running on Windows 7 x64.
Yurii
