14 years ago --- Quote Start --- Can you provide me any sample or suggested reading on how to set that up? --- Quote End --- Sure. What evaluation boards do you have? If I have the same board, I'll modify an existing example for you. --- Quote Start --- How can I driver the synthesis with different configurations and name the images afterwords meaningful? --- Quote End --- Its got nothing to do with synthesis, you just copy the file to a new name :) Tcl commands can be used. --- Quote Start --- Can I directly us the generic parameter in if() statements in the timequest configuration file? --- Quote End --- Sure. In some of my SDC files, I first look to see if a net exists, and then assign a constraint. This allows me to enable/disable features without having to edit the .sdc file. --- Quote Start --- What I'd also like to have in the image are human readable strings to be accessible as read-only storage on the computer interface. Is there any easier way to do that besides creating .mif files? --- Quote End --- Why bother with strings in the image? You'll be using logic cells unnecessarily. If you are reading the registers directly, reading a vendor ID, product ID, and revision as hex values is adequate. This has served every USB device and PCI device out there quite well :) Ok, USB devices do have strings too. If you want to store strings in RAM, then you have to use .mif files or Intel Hex files. I prefer the latter. Cheers, Dave
