14 years ago --- Quote Start --- Currently I have all extra modules in the (main) code and just comment/uncomment the connections between them. Unfortunately I also need to comment/uncomment different sections in the .sdc file to get proper timing analysis. --- Quote End --- Why don't you use parameters (Verilog) or generics (VHDL)? Tcl scripts can be used for synthesis and simulation. Those scripts can set the values of the generics/parameters. The .sdc file is just Tcl, so it can also use the generics/parameters (or different files can be included based on the generics/parameters). --- Quote Start --- An other thing I'd like to have, is some user-readable version information about the image. So how may I have different text strings and version numbers in each image? --- Quote End --- I use; * Board identification * FPGA identification (for multiple FPGAs on a board) * Design ID * Build timestamp (passed in as a Tcl generic) These are all 32-bit registers. Tcl can then format the IDs into strings - no need for the strings to be stored in hardware. You can also add read-only registers for all the generics/parameters. That way your software can read the design ID, then the generics, and then provide the appropriate hardware-specific functions. Cheers, Dave
