8 years agoProgramming the .aocx file with PCIe instead of JTAG cable
Hello guys, This command aocl program <device_name> <your_kernel_filename>.aocx is currently using JTAG cable and programming my FPGA. What should I do/ Which command should I use to program th...
8 years agoHello HRZ,
Yeah you were right. AOCL invokes PCIe first before JTAG. I have connected both USB and PCIe but unable to program. Should I install any kind of additional drivers to program the FPGA. I am getting the error Error (213013): Programming hardware cable not detected when I run quartus_pgm -a command. I am pretty sure the PCIe is properly connected. When I run the helloworld example I get the error MMD FATAL: acl_pcie.cpp:71: can't find handle -1 -- aborting host: acl_pcie.cpp:71: ACL_PCIE_DEVICE* get_pcie_device(int): Assertion `0' failed.
