9 years agoProgramming MAX 10 with .mif
I'm trying to program a 10M50 on the Altera Development Kit. It's programming fine, but I'm not getting the expected readout over UART (I keep getting a semi-random single number continously), so I'd...
9 years agoI simplified the RTL considerably, and now it's just outputting zeroes over UART :confused:
library IEEE;
use IEEE.Std_logic_1164.all;
use IEEE.Numeric_std.all;
entity UTTM is
port (
CPU_RESETn : in std_logic; -- 3.3V LVCMOS
CLK_50_MAX10 : in std_logic; -- 2.5V
CLK_25_MAX10 : in std_logic; -- 2.5V
CLK_LVDS_125_p : in std_logic; -- 2.5V
CLK_10_ADC : in std_logic; -- 2.5V
USER_LED : out std_logic_vector(4 downto 0); -- 1.5V
USER_PB : in std_logic_vector(3 downto 0); -- 1.5V
USER_DIPSW : in std_logic_vector(4 downto 0); -- 1.5V
UART_TX : out std_logic -- 2.5V
end entity UTTM;
architecture RTL of UTTM is
-- UART
component uart_simple port (
i_clk : in std_logic;
I_clk_baud_count : in std_logic_vector(15 downto 0);
i_reset : in std_logic;
i_txdata : in std_logic_vector(7 downto 0);
i_txsig : in std_logic;
o_txrdy : out std_logic;
o_tx : out std_logic
end component;
-- RAM
component RAM port (
data : in std_logic_vector (11 downto 0);
rd_aclr : in std_logic := '0';
rdaddress : in std_logic_vector (13 downto 0);
rdclock : in std_logic ;
rden : in std_logic := '1';
wraddress : in std_logic_vector (13 downto 0);
wrclock : in std_logic := '1';
wren : in std_logic := '0';
q : out std_logic_vector (11 downto 0)
end component RAM;
-- FSM
type statetype is (S0, S1, S2);
signal state, nextstate : statetype;
signal statecode : std_logic_vector(7 downto 0) := (others => '0');
-- UART
signal txdata : std_logic_vector(7 downto 0) := (others => '0');
signal txsig : std_logic := '0';
signal txrdy : std_logic := '0';
signal rdaddress : std_logic_vector (13 downto 0);
signal rden : std_logic;
signal q : std_logic_vector (11 downto 0);
signal TX_activation : std_logic := '0';
signal TX_completion : std_logic := '0';
begin
uart_instance : uart_simple port map (
I_clk => CLK_LVDS_125_p,
I_clk_baud_count => X"32DD", -- 9600 bps @ 125 MHz clock
--I_clk_baud_count => X"043D", -- 115200 bps @ 125 MHz clock
--I_clk_baud_count => X"0088", -- 921600 bps @ 125 MHz clock
I_reset => not CPU_RESETn,
I_txdata => txdata,
i_txsig => txsig,
o_txrdy => txrdy,
O_tx => UART_TX
-- RAM
RAM_inst : RAM port map (
data => (others => '0'),
rd_aclr => not CPU_RESETn,
rdaddress => rdaddress,
rdclock => CLK_LVDS_125_p,
rden => rden,
wraddress => (others => '0'),
wrclock => '0',
wren => '0',
q => q
-- may need to add a first-run variable as RAM has not yet been read out for first UART transmission
tx_RAM_process : process (CLK_LVDS_125_p, CPU_RESETn)
variable i : integer := 0;
begin
if CPU_RESETn = '0' then
i := 0;
txdata <= (others => '0');
txsig <= '0';
rden <= '0';
rdaddress <= (others => '0');
TX_completion <= '0';
elsif rising_edge(CLK_LVDS_125_p) then
if txrdy = '1' and TX_activation = '1' then
if i <= (12500-1) then -- output loop begin
i := i + 1;
txdata <= q(11 downto 4);
txsig <= '1';
rden <= '1';
rdaddress <= std_logic_vector(to_unsigned(i,14));
else
i := 0;
txsig <= '0';
rden <= '0';
TX_completion <= '1';
end if; -- output loop end
end if;
end if;
end process;
FSM_clock_process : process (CLK_LVDS_125_p, CPU_RESETn) is
begin
state <= S0;
else
state <= nextstate;
end if;
end if;
end process FSM_clock_process;
FSM_io_process : process (CPU_RESETn, state, TX_completion, USER_PB) is
begin
TX_activation <= '0';
nextstate <= S0;
USER_LED(3 downto 0) <= "1111";
else
-- default assignments
nextstate <= state;
case state is
-- idle state after reset
when S0 =>
USER_LED(3 downto 0) <= "1110";
if USER_PB = "1110" then
TX_activation <= '1';
nextstate <= S1;
end if;
when S1 =>
USER_LED(3 downto 0) <= "1100";
if TX_completion = '1' then
nextstate <= S2;
end if;
when S2 =>
USER_LED(3 downto 0) <= "1000";
if USER_PB = "0111" then
nextstate <= S0;
end if;
end case;
end if;
end process FSM_io_process;
end architecture RTL;
