14 years ago --- Quote Start --- Same problem, it shows USB Blaster Variant but at progress bar it says Failed :/ Ubuntu 11.04 here... Any solution? --- Quote End --- Ubuntu 11.04 works fine with USB-Blasters. Look at the threads on the subject. http://www.alteraforum.com/forum/showthread.php?t=32179 http://www.alteraforum.com/forum/showthread.php?t=31426 What is your 'variant', I assume some sort of clone? It should also work fine, but perhaps your udev rules are not setup correctly. One caveat: USB-Blasters do not work from virtual machines (VirtualBox or VMWare) - at least when I last checked a few weeks ago. VirtualBox has just released 4.1.4, but I haven't tested it yet. Cheers, Dave
