15 years ago --- Quote Start --- As I understand it that would take a PLL which I would rather avoid if the functionality comes cheaper. Looking at the IOE structure there is "programmable delay" but I am guessing by your comments that this is not _dynamically_ programmable and hence that would be why it would not show up in altiobuf megafunction params. Data rate is slow enough at 250MHz DDR LVDS such that I only really need the dynamic behavior initially for convenience so perhaps I just do a bunch of builds <tick-tock> with the "fixed" "programmable delay" varied and find my happy place. --- Quote End --- Cosmo, Quartus II will do a good job inserting IODelays. I'm dabbling (not really) with a similar set-up. I'm using Cyclone IV though which is different than Arria II GX where the DDR registers are built into the IO-ring and the compiler can't add extra routing delay. But I recompiled (QII9.1sp2) my code for Arria II GX and ended up with a really small hold violation of 7 ps for the Fast model only. But I have a skew of 500 ps on the input data at a 240 MHz frequency, you may have a smaller skew and meet timing. After compilation in the Fitter Report -> Resource Section -> Delay Chain Summary you can see what the compiler added.
