AGofs
6 years agoPrograming .jic file into ISSI IS128LP128 flash memory and connection between Flash memory and FPGA.
I'm using Quartus-II Rev. 18.1 in order to program .jic file into ISSI IS128LP128 flash memory at active serial mode, but without success. 1). How should I connect IS128LP128 (8-pins) to Cyclone-V...
AGofs
6 years agoHi WolfGang,
Unfortunately, I don't have any option to select device family from "Configuration Device" tab.
I'm working with Quartus Prime 18.1 Lite Edition.
The answer you attached is for Quartus 19.1.
So, Is it possible to program .jic file into IS25LP128 flash memory with Quartus prime 18.1 Lite Edition?
Another question is :
How should I connect IS25LP128 to FPGA CycloneV component?
ShafiqY_Intel
6 years agoHi AGofs,
This feature only available starting 18.1.1 Standard version or 19.1 pro version.
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qps-gen-flash-programmer.pdf
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/archives/ug-qpp-gen-flash-programmer-19-1.pdf
I dont think it is possible using 18.1 lite edition.
i'm apologize for any inconvenience.
