Programing .jic file into ISSI IS128LP128 flash memory and connection between Flash memory and FPGA.
Hi AGofs,
You may refer to this solution here:
https://forums.intel.com/s/feed/0D50P00004ImOLLSA3
CBATT (Customer)
a month ago
I believe that this problem may be solved. If not, here on how we manage to get this memory to work with Quartus 19.1 for write, erase and FPGA initialization.
- Open Programmer
- Go to File > Convert Programming File
- Programming file type, select .jic
- Open configuration device using "..."
- Select your device family
- Create a <<new device>>
- Configure according to your memory datasheet
- e.g., name: IS25LP128, ID: 17, Density: 128Mb, Single dummy: 8, Quad dummy: 6
- Select Micron as Flow template
- Change Addressing mode(byte) from each flow tab from 4 to 3
- In initialization tab:
- Remove everything except Read ID (Command 0x9F), Write Enable (Command 0x06) and Write status register (Command 0x01), keep this flow order
- Note that you need a Write Enable before sending other commands, check your memory datasheet for more info
- In erase tab:
- Change Read flag status register to Read status register
- Change Command to 0x05 (ISSI memory uses the READ STATUS REGISTER OPERATION for erase status)
- Change Expected data to 0x00
- Change Expected data mask to 0x01
I hope this helps.
- ShafiqY_Intel6 years ago
Hi AGofs,
This feature only available starting 18.1.1 Standard version or 19.1 pro version.
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qps-gen-flash-programmer.pdf
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/archives/ug-qpp-gen-flash-programmer-19-1.pdf
I dont think it is possible using 18.1 lite edition.
i'm apologize for any inconvenience.
- AGofs6 years ago
Hi WolfGang, Thank you for answer. I've downloaded Quartus Prime Programmer Pro Edition 19.1.0 and started to configure New Device, as you have explained. During configuration I saw the row named "Total Device die". What should I write in this row? I've attached the printscreen to this message. You wrote at point 9 :"Change Addressing mode(Byte)….). Where is it? - AGofs6 years ago
Hi WolfGang, I have another question in addition to previous questions. At 10.(Initialization Tab) You wrote: "Remove everything except…..". As I understand you , only 3 commands must remain: Read ID=>Write enable=>Write Status Register. Every another command from Initialization Tab must be removed . Am I right? - ShafiqY_Intel6 years ago
Hi AGofs,
IS25LP128 do not have stack die. then you should write it as 1.
if MT25QU01G device, it have 2 stacked die. Thus, MT25QU01G should write as 2.
Where is it?
Every tab (Program, Erase, Verify... tab) you need to change address byte from 4 to 3.
Am I right?
Yes, you're right
I'm apologize for delay reply. I'm on Christmas & New Year holiday.
Cheers
