8 years agoProfile.mon is not Generated
Hi, i run the command aoc --profile <mykernel_name>.cl The compiler doesn't return me any error and the compilation only generate .aocx file. Any possible cause on this issue? I've been r...
8 years agoNo, the aoc command does not generate profile.mon. As I said, you have to run the application and then, at run time, profiling info is gathered and profile.mon is generated. Then you supply the profiler with the aocx file and the profile.mon file and get the profiling info.
