8 years agoProfile.mon is not Generated
Hi, i run the command aoc --profile <mykernel_name>.cl The compiler doesn't return me any error and the compilation only generate .aocx file. Any possible cause on this issue? I've been r...
8 years ago --- Quote Start --- You have to run the kernel using the profile aocx file and then you will get the profiling info. Check "Intel FPGA SDK for OpenCL Programming Guide, Section 10 - Profiling Your OpenCL Kernel" and "Intel FPGA SDK for OpenCL Best Practices Guide, Section 4 - Profiling Your Kernel to Identify Performance Bottlenecks" for more info. --- Quote End --- Thank for your reply. If i'm not mistaken, the command should generate both profile.mon and .aocx file (Issue: I don't get the profile.mon file). Both "profile.mon" and ".aocx" file are needed to get the profiling info. Please correct me if I'm wrongly understanding the documentation
