12 years agoprocessing element and work items
Hi there, I have a general question here. If I compile a kernel with BLOCK_SIZE=32, SIMD_WORK_ITEM=2, 2-D work groups. The kernels has attributes as: __attribute((reqd_work_group_size(BLOC...
12 years agoYes, with simd_work_item(2), the compiler generates the same number of process elements (i.e. 1), however, each processing element is wider to do more work.
The "num_compute_units" attribute directly replicates each processing element.
