13 years agoProblems working thru "Using Triple-Speed Ethernet on DE2-115 Boards"
I'm trying to get this running.. it is an 'altera corporation - university program' pdf of a triple speed ethernet design. Sort of a bare-bones way to get ethernet working at 10/100/1000 with a NIOS...
11 years ago --- Quote Start --- I tried it and it is worked on Quartus 12 but there is something the .sof file which is generated has the following name (tse_tutorial_time_limited.sof) did you know if this will make a problem after sometime may be damaged? --- Quote End --- It is time limited because you don´t have a payed license for the nios-core. The design will only work as long as you have your jtag connected to the board.
